Using Xilinx Tools Forum Problems with a simple interrupt pin in vivado/sdk
  • Subscribers 370 subscribers
  • Views 578 views
Hello
Iu2019ve made a very simple (non-axi) custom ip in Vivado and now Iu2019d like to use one of the pins as an interrupt for my Zynq core (NOT microblaze), which already has the IRQ_F2P opened and connected to the pin of my ip. However, my pin doesnu2019t get any interrupt number assigned in xparameters.h inside SDK, like a timer or GPIO would get, once itu2019s connected to the IRQ_F2P of the Zynq core. Iu2019ve found quite a few examples on interrupts in Vivado and SDK, but they donu2019t seem to address my problem. Could someone please tell me what to do inside Vivado, to make my pin work for interrupts (TYPE: intr), like the ones on timers and gpiou2019s? And if it includes a working c code for SDK, I would be so grateful. Iu2019m a complete novice, so please make it as simple as it could possible be.
Thanks a lot :-)
    Hello AGE,
    Have not tried this with a non AXI custom IP core. You will probably have a broader and more knowledgeable audience on one of the Xilinx Community forums that focuses on IP:
    https://forums.xilinx.com/
    -Gary
    Hello Gary.
    Thanks but I've already asked the same quenstion on the xilinx forum, and got no answers :-)
    Cheers
    Allan
    0 e14 Contributor over 9 years ago
    Hello AGE,
    have you solved your problem?
