Using Xilinx Tools Forum Confusion about Xilinx ISE Design Suite
  • Subscribers 367 subscribers
  • Views 514 views
eactor
eactor over 12 years ago
What are the main differences between the option during the install of the ISE Design Suite and which one to use with the ZedBoard?
ISE WebPACK
ISE Design Suite: Logic Edition
ISE Design Suite: Embedded Edition
ISE Design Suite: DSP Edition
ISE Design Suite: System Edition
It is kind of confusing if you are new to the XILINX Tools.
Thanks for adivce
    Would like to add that if you decide to use Vivado 2013.1 do not install the Webpack Edition. Instead install the System Edition and use the webpack license. There is an acknowledged bug that prevents the webpack edition from creating new projects without a work-around.
  • eactor
    0 eactor over 12 years ago in reply to Former Member
    Comes a little bit too late :-/
    Hopefully uninstall works, even if it takes forever.
  • eactor
    Does this problem exist in Windows and in Linux?
  • sa-penguin
    0 sa-penguin over 12 years ago
    For Linux versions of product - which version of ISE should I install on a Zedboard / MicroZed?
    Keeping the dev tools on the dev board would allow me to design & modify "on the go" independent of host PC.
