Using Xilinx Tools Forum arm-xilinx-eabi-gcc seems to be missing
  • Replies 14 replies
  • Subscribers 370 subscribers
  • Views 3164 views
this might be a siple problem but i dont get it.
I try to complete the Xilinx Zed Board "Hello World" tutorial.
Its all fine but when I try to compile it i get a message at my terminal which says "Unable to find full Path for arm-xilinx-eabi-gcc"
I thought this would be a missing compiler for the ARM system.
How can i solve this?
I work on Scientific Linux  with Xilinx EDK 14.2
Thanks for any help!!
    0 Former Member over 13 years ago
    Wuddl,
    Did you follow this how-to?:
    http://wiki.xilinx.com/zynq-tools
    I just followed them the other night and it looks to be updated and working for Ubuntu 12.04 LTS (note you will have to do some additional steps and install some additional 32 bit packages, however they are outlined here: https://sourcery.mentor.com/GNUToolchain/kbentry62)
    Hope that helps!
    Take a look at the open source option as well (gcc-arm-linux-gnueabi):
    http://zynqgeek.blogspot.com/2012/08/zedboard-setting-up-arm-development.html
  • zedhed
    0 zedhed over 13 years ago
    Hi Wuddl,
    I suppose it is possible that somehow the cross toolchain was not installed on your machine during the 14.2 install or the path was not setup correctly.
    If you want to reinstall the cross toolchain and are using Windows, you will want to look to the installer DVD or download folder for the CodeSourcery installers:
    Xilinx_ISE_DS_14.2_P.28xd.3.0CodeSourcery
    t
    Or this folder if you are running Xilinx tools on Linux:
    Xilinx_ISE_DS_14.2_P.28xd.3.0CodeSourcerylin
    -Kevin
    Thanks a lot
    this was all very helpful, and it solved my problem.
    0 Former Member over 13 years ago in reply to Former Member
    Hi Wuddl. How did you solve this problem? It's as same as mine.
    There was simply the CROSS_COMPILE variable missing.
    Just go to the link Tim posted, download the tools and export the PATH it.
    Like:
    export CROSS_COMPILE=arm-xilinx-linux-gnueabi-
    and
    export PATH=<path>/CodeSourcery/2011.09/lin/Sourcery_CodeBench_Lite/bin:$PATH
    (I presume that you work under Linux)
    I am running ISE 14.3 on Ubuntu 12.10.
    I set CROSS_COMPILE and PATH as I did in ubuntu 12.04 but xsdk doesn't seem to pick it up. I get
    make all
    Building file: ../src/ddr_init.c
    /bin/sh: 1: arm-xilinx-eabi-gcc: not found
    It looks like it is still looking for xilinx's version of the arm compiler.
    Hi all,
    I found the root cause.
    If you use Ubuntu, arm toolchain cannot be installed with dash shell!!
    Solution:
    1. sudo dpkg-reconfigure -plow dash
       //set dash as default system shell. Choose "NO"
    2. re-install xilinx ISE
    3. sudo dpkg-reconfigure -plow dash
       //set dash as default system shell. Choose "YES"
    done!!
    Hi
    It seems that under the path:<path>/14.x/ISE_DS/EDK/gnu/,the folder "arm" was missing,try to install ise14.x under the bash shell if you are under linux os.
    Hello. I still can't get rid of this problem. Any ideas?
