Using Xilinx Tools Forum JTAG usb vrs Linux not working need help
  • Subscribers 367 subscribers
  • Views 1831 views
I cannot connect the debugger to the target platform.
Specifically, I have both the UART(usb) and JTAG(usb) cables connected, see output of lsusb {below}, it shows the Cypres device (the UART) and the FTDI FT232H the JTAG(usb).
I downloaded and believe I have installed the Digilent SW drivers correctly, the install program installed files in: /usr/local/lib64/digilent {and various other places}.
The DMESG is reporting the device, but I don't understand why it is being disconnected {see below]
duane@asus:~$ lsusb
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 003 Device 003: ID 04b4:0008 Cypress Semiconductor Corp.
Bus 003 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 003 Device 006: ID 0403:6014 Future Technology Devices International, Ltd FT232H Single HS USB-UART/FIFO IC
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 13d3:5188 IMC Networks
duane@asus:~$
duane@asus:~$ dmesg
[ 6284.051581] usb 3-3: new high-speed USB device number 7 using xhci_hcd
[ 6284.073114] usb 3-3: New USB device found, idVendor=0403, idProduct=6014
[ 6284.073125] usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6284.073131] usb 3-3: Product: Digilent USB Device
[ 6284.073136] usb 3-3: Manufacturer: Digilent
[ 6284.073140] usb 3-3: SerialNumber: 210248518023
[ 6284.075826] ftdi_sio 3-3:1.0: FTDI USB Serial Device converter detected
[ 6284.075915] usb 3-3: Detected FT232H
[ 6284.075922] usb 3-3: Number of endpoints 2
[ 6284.075927] usb 3-3: Endpoint 1 MaxPacketSize 512
[ 6284.075932] usb 3-3: Endpoint 2 MaxPacketSize 512
[ 6284.075937] usb 3-3: Setting MaxPacketSize 512
[ 6284.076443] usb 3-3: FTDI USB Serial Device converter now attached to ttyUSB0
[ 6284.090297] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[ 6284.090331] ftdi_sio 3-3:1.0: device disconnected
duane@asus:~$
    As discussed in your SDK post, I think this issue might be specific to Ubuntu. While Ubuntu is not one of the officially supported operating systems for Xilinx tools ( http://www.xilinx.com/ise/ossupport/index.htm ) there do seem to be users out there making it work. There are posts that detail some of the issues and workarounds that may help, including special Digilent JTAG drivers:
    https://engineering.purdue.edu/elab/wiki/index.php/Xilinx_tools_on_Ubuntu
    http://www.wiki.xilinx.com/Install+Xilinx+Tools
    http://forums.xilinx.com/t5/Installation-and-Licensing/ISE-12-1-on-Linux-Ubuntu-EDK-does-not-start/td-p/73616
    I would also suggest that if you are just starting out to go ahead and begin with the Xilinx Vivado tool suite, as all future examples, tutorials, and tool development will be there vs the ISE/PlanAhead tools.
    -Gary
    Most important link is the first one to "Engineering.purdue.edu"
    0 Former Member over 12 years ago in reply to Former Member
    Problem with digilent JTAG cable, and can be seen by dmesg, but lsusb shows Futurn FTDI
    Sorry because I cannot open the link of the engineering.pudue.edu
    Here is the new link:
    https://engineering.purdue.edu/elab/html/wiki-xilinx-tools-on-ubuntu.html
    -Gary
    Sorry, I have tried this method, and it is not working, could you please help me to check to see if you got any idea.
    I have start a new question with that link:
    http://www.zedboard.org/content/need-help-jtag-cable-djtgcfg-enum-can-detect-lsusb-d-bususb003008-can-work-dmesg-will-detect
    I have no idea how to go on next
    One of our forum members, Sven Andersson, has a blog where he goes through the process of building a ZedBoard design. His development platform is Ubuntu running under a virtual machine. He has been successful in installing and using the JTAG drivers in his Ubuntu 13.10 64 bit installation. Here is his post on the forum:
    http://www.zedboard.org/content/zynq-design-scratch
    And here is a link to his blog: www.zynqfromscratch.com
    Let us know how it works for you.
    -Gary
