Using Xilinx Tools Forum Vivado 2017.2 board definition
  • Subscribers 371 subscribers
  • Views 1045 views
bnlbob
bnlbob over 9 years ago
I have not found how to add a microzed board definition to Vivado 2017.2. Does that information exist?
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello Lambiase,
    Please downloadl the "MicroZed Board Definition Install for Vivado 2015.3, 2015.4, 2016.1, 2016.2, 2016.3, 2016.4" from here http://zedboard.org/support/documentation/1519
    This Board Definition File is the same one that should be used in Vivado 2017.2. The only difference is you must install it in your Vivado 2017.2 directory.
    Josh
  • bnlbob
    0 bnlbob over 9 years ago
    Hi Josh,
    Thanks for your help, but that didn't work.
    In previous versions, the board definition would be read from the "boards\board_files" directory under "data".
    Vivado 2017.2 has a different structure.  It does not have a "boards" subdirectory under "data".
    Instead it reads the board definitions from VivadoHls_boards.xml.  This one file contains information on all the boards it lists.
    This has similar information as with the xml files with the earlier versions, but with a different structure.
    I don't know how to make this conversion.
    Bob
  • jafoste4
    Hello Bob,
    Thanks for the information. I was under the assumption it was all the same. I will install Vivado 2017.2 today and investigate this issue.
    --Josh
  • bnlbob
    0 bnlbob over 9 years ago in reply to jafoste4
    Thanks Josh,
    Bob
  • jafoste4
    Hello Bob,
    I just installed Vivado 2017.2 along with the board definition files. I was sucessful, please install the board defintion files I pointed to above in the following directory C:\Xilinx\Vivado\2017.2\data\boards\board_files
    --Josh
  • bnlbob
    Thanks Josh,
    I see now where I made my mistake.  I was confusing Vivado (where I had an old version) and Vivado HLS, which is newly installed.
    You were a great help, and this solved the problem.
