Using Xilinx Tools Forum EDK DRC problems with default clock settings
  • Replies 10 replies
  • Subscribers 366 subscribers
  • Views 1299 views
gsavaton
gsavaton over 13 years ago
I am trying to follow the tutorial at http://zynqgeek.blogspot.it/2012/08/zedboard-create-planahead-project-with.html
In XPS, after loading the XML board configuration file, DRC completes with no errors.
Back into PlanAhead, I create the top HDL and run the synthesis.
I get a message box with the following message:
DRC check found issues in the design. Please see the console log for more details.
The TCL console reads:
ERROR:EDK - issued from TCL procedure "zynqconfig_do" line 34
   processing_system7_0 (processing_system7) - MHS file editing for Zynq related
   parameters is not allowed. Please use Zynq tab in XPS for PS configuration.
    Value of parameter C_FCLK_CLK0_FREQ (96461533) in MHS conflicts with the
   setting in Zynq tab. Value of C_FCLK_CLK0_FREQ should be 100000000
This message disappears if I modify the input clock frequency in XPS (in the "Zynq" tab, "Clock Generation" block, "Zynq crystal" set to 35 MHz instead of 33.33 MHz) and run the synthesis again.
I am using ISE 14.2 for Linux.
Did anyone experience the same problem?
Guillaume Savaton
    0 Former Member over 13 years ago
    gsavaton,
    What version of the XML did you import into XPS?  Was it the current version from this link:
    http://zedboard.org/sites/default/files/documentations/zedboard_RevC_v2_XML.zip
    Did you follow the how-to that ZynqGeek posted step-by-step?
    It looks like something along the way, perhaps a tcl script, is calculating the wrong clock frequency for the PS.  Can you post your MHS file?  I suggest using pastebin.org.
  • gsavaton
    0 gsavaton over 13 years ago in reply to Former Member
    Yes, I used the RevC v2 XML.
    I think so.
    I also tried to start a project without selecting any board, and added the processing system manually in XPS.
    I got exactly the same result.
    Here it is:
    http://pastebin.com/GPTvS2u7
    It contains this line:
    PARAMETER C_FCLK_CLK0_FREQ = 96461533
    0 Former Member over 13 years ago in reply to gsavaton
    gsavato,
    If you change that line from 96461533 to 100000000 does it work?
  • gsavaton
    Yes.
    I have to change all clock frequency settings, from CLK0 to CLK3, to match the expected frequencies.
    Then synthesis completes with the usual warnings, and I can proceed to implementation and bitstream generation.
    i had the same problem as i used an 13.4 lincense file for my ISE 14.2. As i moved to the license Server of my University all clock problems where gone.
    I had the same problem under linux, but its gone when I unset locales:
    unset LANG
    unset LC_ALL
    I have both commands now in my settings64.sh.
    Credits to http://www.zedboard.org/content/ise-142-bug-reports
    0 Former Member over 13 years ago in reply to Former Member
    I had Swedish locale (Ubuntu 12.04-64bit) and here the decimal sign is the "comma". The "Clock Wizard" scripts do however calculate with the "dot". Meaning that 33,333333MHz will be truncated to 33MHz as input frequency.
    I run 14.4 version.
    In my settings64.sh I override all my Swedish locale with:
    export LC_ALL=en_US.UTF-8
    Hey
    When I launch generate bitstream I have this messages.
    [Edk 24-135] DRC check found issues in the design. Please see the console log for more details.
    [HDLCompiler 1654] Instantiating <system_i> from unknown module <system> ["/home/eukrea/Documents/silica/tutoriel/fpga/lab4/LED_Controller/LED_Controller.srcs/sources_1/edk/system/system_stub.v":60]
    I don't know where is the problem
    I added
    unset LANG
    unset LC_ALL
    unfortunately it des'nt worK.
    hey when I create embedded and I add the processor arm processing system when I generate netlist I had this error whereas I add only the processor Do you can help me ?
    Cordially.
        Value of parameter C_FCLK_CLK0_FREQ (49500000) in MHS conflicts with the
       setting in Zynq tab. Value of C_FCLK_CLK0_FREQ should be 50000000
    I test the manipulation with the version 14.2 I had'nt this problem.
