Using Xilinx Tools Forum petalinux-build fails on device tree generation
  • Subscribers 371 subscribers
  • Views 2138 views
tico0001
tico0001 over 9 years ago
 I can't build petalinux for the MicroZed. I always get this error when it gets to the device tree generation. This error doesn't provide me with any clue as to what is wrong.
Any help would be greatly appreciated.
Thanks!
~F
ERROR: [Common 17-167] Type error
ERROR: [Common 17-39] 'rdi::col_lreplace' failed due to earlier errors.
ERROR: [Hsi 55-1545] Problem running tcl command ::sw_device_tree::post_generate : ERROR: [Common 17-39] 'rdi::col_lreplace' failed due to earlier errors.
    while executing
"lreplace $all_drivers $first_occur_pos $first_occur_pos $console_element"
    ("foreach" body line 12)
    invoked from within
"foreach drv_handle $all_drivers {
set alias_str [get_property CONFIG.dtg.alias $drv_handle]
if {[string match -nocase $alias_str "serial"]} {
i..."
    (procedure "update_alias" line 25)
    invoked from within
"update_alias $os_handle"
    (procedure "::sw_device_tree::post_generate" line 3)
    invoked from within
"::sw_device_tree::post_generate device_tree"
ERROR: [Hsi 55-1443] Error(s) while running TCL procedure post_generate()
generate_target failed
    while executing
"error "generate_target failed""
    invoked from within
"if {[catch {hsi generate_target -dir $project} res]} {
    (file "/home/petalinux/TESTPROJECT/build/tmp/work/cortexa9hf-neon-xilinx-linux-gnueabi/device-tree-generation/xilinx+gitAUTOINC+11f81055d1-r0/dtge..." line 33)
WARNING: /home/petalinux/TESTPROJECT/build/tmp/work/cortexa9hf-neon-xilinx-linux-gnueabi/device-tree-generation/xilinx+gitAUTOINC+11f81055d1-r0/temp/run.do_configure.17298:1 exit 1 from 'eval xsct /home/petalinux/TESTPROJECT/build/tmp/work/cortexa9hf-neon-xilinx-linux-gnueabi/device-tree-generation/xilinx+gitAUTOINC+11f81055d1-r0/dtgen.tcl -ws /home/petalinux/TESTPROJECT/build/../components/plnx_workspace -pname device-tree-generation -rp /home/petalinux/TESTPROJECT/build/tmp/work/cortexa9hf-neon-xilinx-linux-gnueabi/device-tree-generation/xilinx+gitAUTOINC+11f81055d1-r0/git -processor ps7_cortexa9_0 -hdf /home/petalinux/TESTPROJECT/build/tmp/deploy/images/plnx_arm/Xilinx-plnx_arm.hdf -arch 32 ${APP_ARG} ${MISC_ARG}'
ERROR: Function failed: do_configure (log file is located at /home/petalinux/TESTPROJECT/build/tmp/work/cortexa9hf-neon-xilinx-linux-gnueabi/device-tree-generation/xilinx+gitAUTOINC+11f81055d1-r0/temp/log.do_configure.17298)
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello Tico,
    Pelase take a look at issues 53-55 http://zedboard.org/content/microzed-chronicles
    Thank you,
    Josh
  • tico0001
    0 tico0001 over 9 years ago in reply to jafoste4
    Thanks, Josh. I have read quite a few of those and It's nice to finally have a link of all the issues.
    Are you implying that the ONLY way to have petalinux running on the MicroZed is to follow the steps described on issue 53-55?
    Has anyone else ran into the error message I'm getting?
    Thanks.
