Using Xilinx Tools Forum Unable to creat a spidev device, PetaLinux
  • Subscribers 370 subscribers
  • Views 568 views
100charlesb
100charlesb over 11 years ago
I am trying to create a spi_0 device in PetaLinux
v2014.4 without much luck.
I have enabled SPI support in the kernel configuration.
I have created the device in Vivado and routed it to
the EMIO ports. SPI0 appears in the pcw.dtsi file as
&spi0 {
    is-decoded-cs = <0>;
    num-cs = <3>;
    status = "okay";
but there is no device in /dev when I boot the system.
I have done a lot of Googling on this topic but all the
answers I have found seem to be for older systems,
suggesting adding entries to the .dts file
but they seem to be in a different format to what
PetaLinux requires in its system-top.dts file which
is where according to the Workflow tutorial UG1156
I should be putting extra SPI configuration.
Any help would be appreciated
- Charles
  • bhfletcher
    Is there anything in this post that helps? Seems some were able to get it to work with the info here.
    http://forums.xilinx.com/xlnx/board/crawl_message?board.id=ELINUX&message.id=7950
    Bryan
  • 100charlesb
    0 100charlesb over 11 years ago in reply to bhfletcher
    I got a similar result by trial and error, I now have the device
    present. I can open it and send it messages with no errors being
    returned but have yet to actually read any data back from the
    Lime LMS6002D chip I am trying to talk to. I think it might be
    time to get my scope out.
    - Charles
