Using Xilinx Tools Forum Verilog question
  • Subscribers 370 subscribers
  • Views 374 views
Verilog question
dyessgg
dyessgg over 11 years ago
OK, I am primarily a software engineer picking up Verilog programming.  In software, I like to parameterize "magic numbers" like AXI Cache definitions, Lock values, field sizes, etc to avoid problems later with mismatches.  I like to put these generic constants in a separate header file that can be consistently included across every project.
Now to my problem.  Everything I have tried (`define, parameter, localparam) has given me syntax errors:
Header file:
`define C_AXI_AxBURST_SIZE_WIDTH    3
`define C_AXI_AxBURST_SIZE_1  C_AXI_AxBURST_SIZE_WIDTH'b000t// 1 byte wide
Main body:
Module Xxx
parameter C_M_AXI_ADDR_WIDTH = 32,
parameter C_M_TARGET_SLAVE_BASE_ADDR = 32'h4000_0000,
I get syntax errors at the constant definitions after the ' character.
I know it's something simple.  Can anyone spot what I'm doing wrong?
  • dyessgg
    0 dyessgg over 11 years ago
    It looks like there were two problems:
    1. There appears to not be a valid way to add "parameter" declarations or any other kind of symbolic constants outside the module definition.
    2. Xilinx Verilog appears to not allow the use of a parameter value in the definition of a constant:
    parameter Width = 7,
    parameter SomeParam = Width'h0000000
    It will constantly complain about a syntax error near "'h"
    You might want to try posting your question on one of the tool related Xilinx Community Forums. Perhaps the 'Synthesis' forum:
    http://forums.xilinx.com/t5/Synthesis/bd-p/SYNTHBD
    -Gary
