Using Xilinx Tools Forum Can't program second Zedboard
  • Subscribers 370 subscribers
  • Views 388 views
I have multiple Zedboards for some lab experiments.
On the first board, i have no issues.
On the second board however, I can program the FPGA, but not program/debug the arm core.  When programming the FPGA.  I have tracked the issue down to the jtag cable name.  When programming the fabric, it has successfully found the new cable name and programmed it, but when trying to either debug, or program the flash, it is trying to connect to the cable from the first board.  I cannot find the setting to change this so i can attach to the second board.  I am running Windows 7 and SDK 2015.4.   Any help is appreciated.
    I have not tried to connect multiple board/zynq devices to a single PC via JTAG but you might take a look at this Xilinx Answer Record and see if it is helpful:
    http://www.xilinx.com/support/answers/64252.html
    -Gary
