Using Xilinx Tools Forum Programming Microzed on Windows 10
  • Subscribers 370 subscribers
  • Views 518 views
e14 Contributor over 8 years ago
So, up to now, I've been using ISE 14.7 iMpact to program the flash on the MicroZed using a .mcs file created following the procedure in the tutorial.  I now have to migrate to Windows 10, and ISE doesn't support the Zynq in Win 10, only the Spartan-6.
Is there some way to program the flash on the Microzed using Vivado tools?  I'm already using Vivado 2016.1 for my project, but the hardware manager in Vivado seems to only find the Zynq.
  • jafoste4
    0 jafoste4 over 8 years ago
    Yes you can program the .mcs file into your MicroZed either via the hardware manager or SDK.
    Via the HW manager you do this by right clicking on the zynq device, then select add configuration memory. You then define the memory component(QSPI) and then it will give you an option to program it.
    --Josh
