Using Xilinx Tools Forum UART Connection using SDK Terminal under Linux
  • Subscribers 370 subscribers
  • Views 437 views
I am struggling to get an UART-connection to my Zedboard.
I tried to run the "Hello World" example on the Zedboard.
The second, the programming of the elf file completes, the SDK crashes/shuts down.
If I don't open a serial connection in the sdk, programming fails with an error stating, that there is no serial connection available.
Any ideas?
kind regards
    Did you check whether your Hardware Design in Vivado contains the uart you want to interface (uart0/uart1)?
    And that it was correctly selected in the BSP configuration?
    Ron
