Using Xilinx Tools Forum Serializer on Vivado
  • Subscribers 371 subscribers
  • Views 952 views
muratt
muratt over 8 years ago
I am working on a project in which I need to give a serialized data to the PMOD pins of the FMC Carrier Card V2 of PicoZed Embedded Vision Kit. I need to get an 8 bit input and create a 1 bit output with the clock speed multiplied with 8. However, I could not find an IP which can be used in serialization. Is there any way I can implement a serializer?
Thanks.
  • bkamen
    0 bkamen over 8 years ago
    Have you considered using SPI or I2C (readily available in various forms) that do the work for you?
  • drozwood90
    0 drozwood90 over 8 years ago
    Hi there,
    depending on your speeds, the easiest thing I can think of is just use a FIFO.  Set it to 8 bit input and 1 bit output.
    Then just clock at the correct speeds.
    The best way to do this would be to pick a protocol and use that.  Generally those IP will already include all the access to the SERDES blocks.  Traditionally those are used more with transceivers.
    --Dan
  • muratt
    0 muratt over 8 years ago
    Thank you. As soon as our circuits get ready I will try them.
