Using Xilinx Tools Forum Vivado GND assignments
  • Subscribers 369 subscribers
  • Views 448 views
Good day. I hope somecan can answer this cause it bugs me. On the reference design for PCIe root complex there are pins that go to ports that are not connected to anything. I will use the INTX_MSI_Request as example. It is an input to PCIe block and ties to an input port.
The input port is not mapped to an I/O pin in the constraints file.
When U look at elaborated schematic it is tied to GND.
I've tried enabling filters etc to look at tie offs.
Now if I do my own design and route pin to a port and unassign it, Vivado complains about it and the bitstream generation fails.
Why does Vivado treat the pin this way in the avnet ref design but if I do my own its different. Same IP, same pin, same everything.
Thxs
  • drozwood90
    0 drozwood90 over 10 years ago
    Hi there,
    Can you provide more information?
    Which board are you using?  Which version of the tools?
    Which example?  You only mention that you are using "the reference design"
    --Dan
