    • Avnet Boards Community
Using Xilinx Tools Forum Xilinx Forum Dup:  Linux DMA Cleanup after transaction timeout
  • Subscribers 335 subscribers
  • Views 551 views
bkamen
bkamen over 7 years ago
I have the following over on the Xilinx forum - so far no one's looked at it. (so few people doing DMA? ;) )
I'm using dma_alloc_coherent for dma operations -- and it works great as long as the transaction doesn't timeout. (which is a condition that's expected to occur).
After the initial timeout, DMA stops working for every subsequent attempt. (see below)
dma_terminate_all() looks like should be what I should use, but I get first time use dmesg of:
[   35.146414] xilinx-dma 40400000.dma: Cannot stop channel eeaff410: 0
[   36.151393] xilinx-dma 40400000.dma: Cannot stop channel eea30350: 0
(DMA doesn't clean  up -- and doesn't go back to working -- and no more messages like the above occur on sequential timeouts.)
Is there some cleanup step I'm missing? (this is Petalinux 2015.4)
 -Ben
I originally used kzalloc with small buffers combined with the sequence of:  (get/release dma channel is on open/close of driver)
dma_map_single ()
dmaengine_prep_slave_single ()
init_completion()
dma_async_issue()
wait_for_completion_timeout()
ucpi_dma_ch_unmap()
it worked fine.
I switched to dma_mmap_coherent() and the sequence is now: (get/release dma channel is on open/close of driver)
init_completion()
dma_async_issue()
(tried with dma_terminate_call() and without)
ucpi_dma_ch_unmap()
  • bkamen
    0 bkamen over 7 years ago
    I found the problem....
    it turns out dma_terminate_all(chan); is the way to go...
    but I found 2 bugs in the FPGA DMA IP and 2 (maybe 3) bugs in the XIlinx Driver code.
    Soooo... yay.
