Using Xilinx Tools Forum Docker on Petalinux
  • Subscribers 371 subscribers
  • Views 2324 views
Docker on Petalinux
e_rush
e_rush over 8 years ago
Hi! I'm trying to build petalinux image with docker on it and run it on QEMU. So far I've added docker to user packages via petalinux-config and built it. But wherever I try to boot it with qemu error message appears. Any help would be appretiated!
  INFO: The image provided is a zImage
  INFO: Set QEMU tftp to /home/e_rush/docker_test/images/linux
  INFO: TCP PORT is free
  INFO: Starting arm QEMU
  INFO:  qemu-system-aarch64 -M arm-generic-fdt-7series -machine linux=on   -serial /dev/null -serial mon:stdio -display none -kernel /home/e_rush/docker_test/build/qemu_image.elf -gdb tcp::9000 -dtb /home/e_rush/docker_test/pre-built/linux/images/system.dtb  -net nic,vlan=1 -net user,vlan=1,tftp=/home/e_rush/docker_test/images/linux -net nic -device loader,addr=0xf8000008,data=0xDF0D,data-len=4 -device loader,addr=0xf8000140,data=0x00500801,data-len=4 -device loader,addr=0xf800012c,data=0x1ed044d,data-len=4 -device loader,addr=0xf8000108,data=0x0001e008,data-len=4 -device loader,addr=0xF8000910,data=0xF,data-len=0x4
  qemu-system-aarch64: -net nic,vlan=1: 'vlan' is deprecated. Please use 'netdev' instead.
  qemu-system-aarch64: warning: vlan 0 is not connected to host network
  rom: requested regions overlap (rom bootloader. free=0x0000000004ca8be8, addr=0x0000000000000000)
  Uncompressing Linux... done, booting the kernel.
Error: unrecognized/unsupported machine ID (r1 = 0x00000d32).
Available machine support:
ID (hex) NAME
ffffffff Generic DT based system
ffffffff ARM-Versatile Express
ffffffff Xilinx Zynq Platform
Please check your kernel config and/or bootloader.
Steps I performed before:
1) Installed Vivado and Petalinux Tools
2) Downloaded zedboard bsp
3) Created project with "petalinux-create -t project -n docket_test -s bsps/zed.bsp"
4) Then I've edited $PROJ/project-spec/meta-user/recipes-core/images/petalinux-image.bbappend to add docker (IMAGE_INSTALL_append = " docker")
5) With petalinux-config -c rootfs enabled docker recipes
6) Built image with petalinux-build
7) Replaced prebuilt image with petalinux-package --prebuilt --force
8) Tried to boot with petalinux-boot --qemu --prebuilt 3
  • jafoste4
    0 jafoste4 over 8 years ago
    hello,
    What deveopment hardware are you using/targeting?
    --Josh
  • e_rush
    0 e_rush over 8 years ago in reply to jafoste4
    I have created project using zedboard bsp from xilinx site
  • e_rush
    Sorry I wasn't able to write more info before. System tagged my messages as spam
  • jafoste4
    Are you developing this for use with the Zedboard? Or are you using this as a starting point for a custom board?
    --Josh
  • e_rush
    I am developing this for a Zedboard. Moving to custom board is possible in the long term.
