Using Xilinx Tools Forum Compiler ARMCC
  • Subscribers 363 subscribers
  • Views 457 views
Compiler ARMCC
I have a problem (many errors) when i change the BSP's settings to use the ARMCC compiler.
Indeed, i need to use this toolchain, but i have several errors when i modify the Board Support Packae Settings, that i navigate to drivers => cpu_cortexa9 and change the following parameters :
   compiler: armcc
   archiver: armar
The errors are :
make: *** [ps7_cortexa9_0/lib/libxil.a] Erreur 2
make[1]: *** [_sys_close.o] Erreur 1
make[1]: *** [_sys_exit.o] Erreur 1
make[1]: *** [_sys_iserror.o] Erreur 1
make[1]: *** [_sys_istty.o] Erreur 1
ps : I used Xilinx ISE 14.4
    The error message is always :
    Error: C9932E: Cannot obtain license for Compiler (feature compiler5) with license version >= 5.0201301
    Cannot find license file.
    The license files (or license server system network addresses) attempted are
    listed below.  Use LM_LICENSE_FILE to use a different license file,
    or contact your software provider for a license file.
    Feature:       compiler5
    Filename:      C:flexlmlicense.dat
    License path:  C:flexlmlicense.dat;
    FLEXnet Licensing error:-1,359.  System Error: 2 "No such file or directory"
    For further information, refer to the FLEXnet Licensing documentation,
    available at "www.flexerasoftware.com".
