Using Xilinx Tools Forum no gnu arm in edk installed from ISE 14.5
  • Subscribers 350 subscribers
  • Views 221 views
As title, I choose the default from system edition. however I didn't find anything installed under EDK/gnu for arm.
what I need is libxil and such to build fsbl. How to get those libraries?
  • bhfletcher
    0 bhfletcher over 12 years ago
    Sounds like something went bad with your install. System Edition should get you something under EDK/gnu/arm. What OS are you using?
    Bryan
    I have the same problem too, on a Linux Mint Olivia system. /bin/sh is set to bash (not dash).
    Installing the toolchain manually from the Xilinx SDK package helps.
