Using Xilinx Tools Forum Cannot connect 2014.4 SDK to zedboard on linux
  • Subscribers 363 subscribers
  • Views 308 views
I'm trying to follow the tutorial:
  http://zedboard.org/course/developing-zynq%C2%AE-7000-all-programmable-soc-software-vivado-20133
And all is well until lab 5 and I can't connect to
the zedboard. I'm using 2014.4 SDK on Ubuntu 14.04.
For good or bad I've installed the drivers from
  /opt/Xilinx/SDK/2014.4/data/xicom/cable_drivers/lin64/install_script/install_drivers/install_drivers
Below is the output from dmesg and we see ttyACM0 and ttyUSB0 setup:
[   46.165247] usb 3-3: new high-speed USB device number 2 using xhci_hcd
[   46.186229] usb 3-3: New USB device found, idVendor=0403, idProduct=6014
[   46.186234] usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[   46.186236] usb 3-3: Product: Digilent USB Device
[   46.186239] usb 3-3: Manufacturer: Digilent
[   46.186241] usb 3-3: SerialNumber: 210248570449
[   46.425146] usb 3-4: new full-speed USB device number 3 using xhci_hcd
[   46.445927] usb 3-4: New USB device found, idVendor=04b4, idProduct=0008
[   46.445932] usb 3-4: New USB device strings: Mfr=1, Product=2, SerialNumber=4
[   46.445935] usb 3-4: Product: Cypress-USB2UART-Ver1.0G
[   46.445937] usb 3-4: Manufacturer: 2012 Cypress Semiconductor
[   46.445939] usb 3-4: SerialNumber: 03680155280E
[   46.453987] usbcore: registered new interface driver usbserial
[   46.453999] usbcore: registered new interface driver usbserial_generic
[   46.454008] usbserial: USB Serial support registered for generic
[   46.457113] cdc_acm 3-4:1.0: This device cannot do calls on its own. It is not a modem.
[   46.457135] cdc_acm 3-4:1.0: ttyACM0: USB ACM device
[   46.457402] usbcore: registered new interface driver ftdi_sio
[   46.457415] usbserial: USB Serial support registered for FTDI USB Serial Device
[   46.457500] ftdi_sio 3-3:1.0: FTDI USB Serial Device converter detected
[   46.457538] usb 3-3: Detected FT232H
[   46.457540] usb 3-3: Number of endpoints 2
[   46.457541] usb 3-3: Endpoint 1 MaxPacketSize 512
[   46.457543] usb 3-3: Endpoint 2 MaxPacketSize 512
[   46.457545] usb 3-3: Setting MaxPacketSize 512
[   46.457646] usb 3-3: FTDI USB Serial Device converter now attached to ttyUSB0
[   46.459150] usbcore: registered new interface driver cdc_acm
[   46.459152] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
But for the life of me I can't figure out how to connect the SDK to
these devices. Any help appreciated!!
-- Wink
    I followed the instructions of Sven Andersenu2019s blog Zynq design from scratch. Part 13
    (http://svenand.blogdrive.com/archive/172.html#.VHe8Verd-90).
    and installed the Adept 2 runtime and utilities
    (http://www.digilentinc.com/Products/Detail.cfm?NavPath=2,66,828&Prod=ADEPT2).
    I grabbed the u201Clinux taru201D files to my home Downloads diretory and untaru2019d them
    (tar -xvf xx) and as Sven advised I installed them as suggested by the install script
    to their default locations. I didnu2019t install plugin for ISE which I donu2019t have and
    is now deprecated. Also I didnu2019t install the 52-digilent-usb.rules
    to /etc/udev/rules.d as it was already there, probably from the sdk or vivado install.
    I then ran udevadm to reinit and tried the u201Cdjtgcfg enumu201D:
    wink@ssi-primary:~/Downloads$ djtgcfg enum
    Found 1 device(s)
    Device: Zed
        Product Name:   Digilent Zed
        User Name:      Zed
        Serial Number:  210248570449
    But the u201Cdjtgcfg init -d Zedu201D didnu2019t work:
    wink@ssi-primary:~/Downloads$ djtgcfg init -d Zed
    ERROR: unable to init JTAG, err code=3    << Something like this
    So I rebooted and guess what it worked!!
    Initializing scan chain...
    Found Device ID: 23727093
    Found Device ID: 4ba00477
    Found 2 device(s):
        Device 0: ARM_DAP
        Device 1: XC7Z020
    I was then able to complete step 7 of experiment 1 "Program the FPGA", of lab 5, Yea!
    Next was experiment 2 where we run the Hello_Zynq app. Here 14.4 is different from the
    vivado 13.3 and rather than an u201CInitializationu201D tab there is a u201CTarget Setupu201D tab which
    was already populated with ps7_init.tcl, so I skipped step 3. And then step 4 didnu2019t
    work because the options for the STDIO configuration only had /dev/ttyS0 or JTAG and
    I needed /dev/ttyACM0.
    So I fired up minicom and saw the Hello World output, finally.
    $ sudo minicom -D /dev/ttyACM0 -b 115200 -8 -o
