Using Xilinx Tools Forum Having problem with SDK 2017.1 when I am targeting UltraZed PCIe Carrier Card
  • Subscribers 372 subscribers
  • Views 1306 views
100mithunsaha
100mithunsaha over 8 years ago
Currently I am using Xilinx SDK 2017.1. I created a design using Vivado 2017.1 and then created "hardware platform" on same project directory "proj_dir.sdk". After that I launched SDK from vivado, then created BSP based on "psu_cortexr5_0". After that whenever I am trying to creat application project, everytime message pops-up "rdi_xsct.exe  has stopped working". It also giving 2 options "check online for a solution and close the program" or "close the program". After selecting "check online for a solution and close the program" couple of time, I can't select the Use existing BSP. Could you please help me asap? I can;t go further of work due to this reason.
Thanks in advance. I look forward to hearing from you.
  • jafoste4
    0 jafoste4 over 8 years ago
    Hello Mithun,
    Based on what you are describing, it appears to be tool related in which it won't allow you to create an application project.
    My first suggestion would be to Ask this question over at the XIlinx forum and see if they have seen this SDK bug.
    My second suggestion would be to reinstall your tool set.
    Josh
  • 100mithunsaha
    0 100mithunsaha over 8 years ago
    Thanks for you reply, JFoster. Yes, Its tool issue and I already raised there. It has been resolved from Xilinx Support team .
  • donseg1
    0 donseg1 over 8 years ago in reply to 100mithunsaha
    I'm experiencing the same issue with rdi_xsct.exe on my PC running Windows 10 machine with SDK 2017.1. Could you please post here the fix you got from Xilinx? Many thanks.
  • 100mithunsaha
    0 100mithunsaha over 8 years ago in reply to donseg1
    Xilinx suggested to delete the .metadata folder in SDK root directory which resolved my problem.
