Using Xilinx Tools Forum Ultrazed-EG IOCC stopped at u-boot
  • Subscribers 368 subscribers
  • Views 972 views
  • petalinux
100yogesh
100yogesh over 3 years ago
I am new to petalinux and ultrzed-EG IOCC module. I am trying to bring up the petalinux and did not succeed yet.
What did I do?
1. Created xsa file from vivado 2021.2 using the AVNET board presets
2. petalinux-build and created the necessary files and BOOT.bin using the petalinux-package --boot command. Here i specified all the files like, u-boot, dtb, pmufw, atf, image.ub and boot script boot.src.
3. While package i got an error saying the previous section overruns the current so had to use the --offset 0xF40000. With this i am able to package the BOOT.bin. But i am not sure how this works.
4. Formatted the sd-card: Installing Ubuntu on Xilinx ZYNQ-7000 AP SoC Using PetaLinux | by Chathura Rajapaksha | Developments and Implementations on ZYNQ-7000 AP SoC | Medium
Select the SD card in gparted
Make sure its unmounted and delete the partition of the SD card so that it displays ‘unallocated’ in gparted
Right click the unallocated space and create a new partition with following settings, Free Space Proceeding (MiB): 4, New Size (MiB) : 512, File System : FAT32, Label : BOOT. Don’t change other settings and click Add to finish.
Right click the remaining unallocated space and create a new partition with following settings, Free Space Proceeding (MiB): 0, Free Space Following(MiB): 0, File System : ext4, Label : rootfs. Don’t change other settings and click Add to finish.
Apply all changes to create the partitions.
5. Copied only the BOOT.bin to the BOOT partiotion.
6. Inserted sd-card back into ultrazed and restarted with the uart connected
7. Able to see prints on putty, but eventually halts at u-boot prompt.
Support required:
1. Can anyone help me to understand what i missed.
2. Where can i get information on how the boot, u-boot and offsets work?
3. When dealing with sd-card boot source, what files to copy to what partition.
thanks in advance,
Yogesh
  • 100yogesh
    0 100yogesh over 3 years ago
    The serial port dump is like this,
    Xilinx Zynq MP First Stage Boot Loader
    Release 2021.2   Oct 13 2021  -  07:15:53
    NOTICE:  BL31: v2.4(release):xlnx_rebase_v2.4_2021.1_update1-23-g9188496b9
    NOTICE:  BL31: Built : 07:41:24, Oct 13 2021
    U-Boot 2021.01 (Oct 12 2021 - 09:28:42 +0000)
    CPU:   ZynqMP
    Silicon: v3
    Board: Xilinx ZynqMP
    DRAM:  2 GiB
    usb dr_mode not found
    PMUFW:  v1.1
    EL Level:       EL2
    Chip ID:        zu3eg
    NAND:  0 MiB
    MMC:   mmc@ff160000: 0, mmc@ff170000: 1
    Loading Environment from FAT... *** Warning - bad CRC, using default environment
    In:    serial
    Out:   serial
    Err:   serial
    Bootmode: SD_MODE1
    Reset reason:   EXTERNAL
    Net:
    ZYNQ GEM: ff0e0000, mdio bus ff0e0000, phyaddr -1, interface rgmii-id
    No ethernet found.
    Hit any key to stop autoboot:  0
    switch to partitions #0, OK
    mmc1 is current device
    Scanning mmc 1:1...
    libfdt fdt_check_header(): FDT_ERR_BADMAGIC
    Scanning disk mmc@ff160000.blk...
    Scanning disk mmc@ff170000.blk...
    Found 5 disks
    No EFI system partition
    BootOrder not defined
    EFI boot manager: Cannot load any image
    JTAG: Trying to boot script at 20000000
    ## Executing script at 20000000
    Wrong image format for "source" command
    JTAG: SCRIPT FAILED: continuing...
    mmc0(part 0) is current device
    Scanning mmc 0:1...
    Scanning mmc 1:1...
    zynqmp_qspi spi@ff0f0000: Warning: SPI speed fallback to 100 kHz
    SF: Detected n25q256ax1 with page size 512 Bytes, erase size 128 KiB, total 64 MiB
    device 0 offset 0x3e80000, size 0x80000
    SF: 524288 bytes @ 0x3e80000 Read: OK
    QSPI: Trying to boot script at 20000000
    QSPI: SCRIPT FAILED: continuing...
    no devices available
    NAND: SCRIPT FAILED: continuing...
    starting USB...
    No working controllers found
    USB is stopped. Please issue 'usb start' first.
    starting USB...
    scanning bus for devices...
    SATA link 0 timeout.
    SATA link 1 timeout.
    AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
    flags: 64bit ncq pm clo only pmp fbss pio slum part ccc apst
    Device 0: unknown device
    starting USB...
    No ethernet found.
    missing environment variable: pxeuuid
    missing environment variable: bootfile
    Retrieving file: pxelinux.cfg/00000000
    No ethernet found.
    No ethernet found.
    No ethernet found.
    No ethernet found.
    No ethernet found.
    No ethernet found.
    No ethernet found.
    No ethernet found.
    Retrieving file: pxelinux.cfg/default-arm-zynqmp-zynqmp
    No ethernet found.
    No ethernet found.
    No ethernet found.
    No ethernet found.
    Config file not found
    starting USB...
    No ethernet found.
    No ethernet found.
    ZynqMP>
