ZedBoard Hardware Design 3D model of zedboard
  • Subscribers 360 subscribers
  • Views 1126 views
Is there available any 3D model of zedboard that can be used in SketchUp SW.
I was thinkin of making case for zedboard and I'm missing height information.
RazorLab seems to be ok place for laser cutting acrylic. That place seems to be pretty cheap for making cases.
http://www.razorlab.co.uk/
    I don't know of any 3D module that is being supplied by Avnet, sorry.
    I just measured my Zedboard and the highest point off the table is the Ethernet jack which is about 2.6 cm.
    The board is 18.2 cm X 13.6 cm, but with the PMOD and SDCard it measures 17.7 cm X 15 cm.
    Hope that helps!
  • zedhed
    0 zedhed over 13 years ago
    Hi Limba, this is an interesting idea that I also shared for making a ZedBoard enclosure and modeling it.  I dug around and was able to come up with a STEP format which I have used at previous jobs with SolidWorks to match PCB features up to mechanical designs for injection molded plastics.  I do not have access to SolidWorks to test it out, but I was able to find a STEP to 3DS converter.  This should enable a .3DS model file to be opened in 3D Studio Max or to be imported into SketchUp.
    Once again, I do not have access to 3D Studio Max to test it out, but I was able to import the .3DS file into Google SketchUp 8.  The model does not look all that spectacular after the SketchUp import process and the model is not to scale either.  I found that I needed to scale the imported component up by a factory of 39.375 before it was fairly close to the dimensions found in the mechanical drawing.
    If you are interested in trying this for yourself, the model files have been posted in the Mechanical Drawing subsection on the ZedBoard.org Documentation page.
    As I mentioned, after going through the SketchUp import process, the component is a little rough but you should be able to see the rough component heights, connector alignments, and the PCB mounting holes positions as well.  Please be sure to double check any models against your real life ZedBoard before committing to any particular mechanical design.
    Feel free to share with the community on how your enclosure fabrication goes, we would love to hear it.
    -Kevin
    Have access to solidworks (not sure on 3dsmax) but don't know how to use either yet (solidworks is on the list to learn ,  along with unity and blender)
    want a small enclosure with fan/s  - air temp gets fairly warm here in summer
    Wouldn't mind solar powering it for a couple of projects but don't have a large enough panel spare.
    I've already added a small heat sink on the zynq chip, one of the stick heatsinks from jaycar
    http://www.jaycar.com.au/productView.asp?ID=HH8580
    Are you actually seeing temperatures that require a heat sink?  Or just being cautious based on previous FPGA experience?  The new 7-Series FPGA's are crazy low power, and the ARM sub system on 28nm silicon should take next to nothing for power.  the 7020 really shouldn't need a heat sink unless you are in some pretty high temperatures and have a fan.
    Its getting reasonably warm sitting there with just default sd card image running, on my desk (office is about 22 *C  - airconditioned)
    Just being cautious as we get fairly warm in summer and I prefer not cooking dev boards.
    We get a few days around 40-45*C in summer with a lot between 25*C and 35.
    Air temps depending on where projects are located can get fairly warm. Not uncommon to see 60*c temps inside fan cooled enclosures in summer.
