ZedBoard Hardware Design SD Card example design using standalone SDK project
  • Subscribers 360 subscribers
  • Views 2517 views
Having problems using the FatFs APIs for the SD card in standalone platform ?
This article provides a step-by-step guide on configuring the SD / SDIO controller on the Zynq chip, and using the FatFs (File Allocation Table File System) Library.
http://embeddedcentric.com/data-logging-using-sd-cards/
  • narrucmot
    narrucmot over 5 years ago in reply to jothin +1 suggested
    The OP here is over 5 years old, making it quite likely the broken link won't be fixed. Hopefully it will, but just in case it isn't here are a couple of useful Xilinx resources for using the FATFS sw…
  • bhfletcher
    Thanks for sharing!
    Bryan
  • jothin
    0 jothin over 5 years ago
    Hi
    The link is broken. Can you share?
    J
  • narrucmot
    0 narrucmot over 5 years ago in reply to jothin
    The OP here is over 5 years old, making it quite likely the broken link won't be fixed.  Hopefully it will, but just in case it isn't here are a couple of useful Xilinx resources for using the FATFS sw library:
    Xilinx UG643:
    https://www.xilinx.com/support/documentation/sw_manuals/xilinx2020_2/oslib_rm.pdf
    Xilinx wiki page:
    https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841771/xilffs
    --Tom
