ZedBoard Hardware Design Not detecting eth0 gigabit ethernet
  • Subscribers 358 subscribers
  • Views 264 views
I am using Zedboard and design given on this blog:
http://shakithweblog.blogspot.kr/2012/12/getting-sobel-filter-application.html
after this I had to run an application which takes the camera frames from eth0
but when I am running ifconfig command it only shows this:
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:8 errors:0 dropped:0 overruns:0 frame:0
          TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:592 (592.0 B)  TX bytes:592 (592.0 B)
I guess its the internal loop only it's not showing about the eth0 thats why in my application I am not able to get any camera frames.
Please tel me how can I resolve this ?
  • bhfletcher
    0 bhfletcher over 12 years ago
    I suggest you use one of the reference designs on zedboard.org and make sure your ethernet/cable/PC setup is working properly. Then compare that design to the blog design. If you still can't figure it out, you might want to contact the owner of the blog.
    Bryan
