ZedBoard Hardware Design zynq base trd 2013.2 convert to zedboard
  • Subscribers 359 subscribers
  • Views 368 views
I have do these Modification
1.set the 2 iic both emio
2.change the mem address 0x30000000 to 0x18000000
3.because the zedboard Y9 pin is not a lvds clock.
so I change it .
set_property PACKAGE_PIN Y9 [get_ports my_video_clk]
set_property IOSTANDARD LVCMOS25 [get_ports my_video_clk]
but implementation failed.
[Place 30-120] Sub-optimal placement for a BUFG-BUFG cascade pair. my_video_clk_IBUF_BUFG_inst, system_top_i/Video_Capture/VIDEO_MUX_0/U0/VIDEO_SEL_GEN[0].BUFGMUX_INST, fmc_imageon_hdmii_clk_IBUF_inst, system_top_i/Video_Capture/VIDEO_MUX_0/U0/VIDEO_SEL_GEN[0].BUFGMUX_INST, my_video_clk_IBUF_inst, and my_video_clk_IBUF_BUFG_inst
how can I fix this problem?
  • bhfletcher
    0 bhfletcher over 12 years ago
    Did you already look at the Xylon-provided port of this TRD?
    http://zedboard.com/node/1394
    Bryan
    hi Bryan,
    thanks for your reply.
    I have looked the xylon ported TRD
    it's based on ise 14.3
    but I want to use the vivado 2013.2 version TRD.
    I found the solution to sovle this problem.
    here is the link
    http://forums.xilinx.com/t5/General-Technical-Discussion/zynq-base-trd-2013-2-convert-to-zedboard/td-p/376343
