ZedBoard Hardware Design XAPP1093 running on Zedboard
  • Subscribers 353 subscribers
  • Views 596 views
I'm trying to implement the XAPP1093 on Zedboard. However, I'm facing some problems. One of them is that I'm not seeing anything coming from the Microblaze through UART.
I have a RS232 PMOD from Maxim where I routed it to Microblaze to check if the processor is working, but I also didn't receive nothing.
I already checked several times the addresses from both processors and everything seems to be ok.
Does anybody tried to implement the XAPP1093 on Zedboard? If yes, is there a special trick to put the design to work?
Thank you!
    You may know this, but XAPP1093 targets the ZC702 eval board. You will need to target the ZedBoard and rebuild the project and boot files.
    That said, could you tell us what version ZedBoard you are using (Rev C or Rev D) as well as the version of Xilinx tools you are using and the host OS you are running them under on your PC.
    -Gary
    0 Former Member over 11 years ago in reply to Former Member
    Hi Gary,
    thank you for your reply.
    Yes, I know that XAPP1093 targets the ZC702. I'm trying to implement the design on Zedboard based on the document and the project files. Only the ARM works well.
    I'm using Zedboard Rev C with ISE Design Suite 14.5. I also tried with Vivado 2014.2. My OS is Windows 7 Professional SP1.
    Hi Gary,
    thank you for the reply.
    I'm trying to implement the XAPP1093 based on its document and source files. I changed (very carefully) the address map to match with the Zedboard memory. The ARM is working well, but the Microblaze not.
    I'm using the Zedboard Rev C together with ISE Design Suite 14.5. I also tried to use the Vivado 2014.2. My OS is Windows 7 Professional SP1.
    Thank you.
    0 Former Member over 10 years ago in reply to Former Member
    Hello Lucas,
      Could you please tell me how did you change the address map to match the zedboard memory?
