ZedBoard Hardware Design can I write my own SPI interface controller in VHDL only
  • Subscribers 360 subscribers
  • Views 361 views
sunsun1437
sunsun1437 over 8 years ago
I have one of Zedboard, i need to interface a external board which will be connected to the SPI interface. There are only a few input/output pins, clk, enable, data_latch, din, dout pins. Can I write my own SPI controller and using PLL to generate the 50 MHz SPI clock?
I have no experience using the embedded on board CPU and using the SDK tool. Can I make it to work using hardware only (verilog/VHDL only) ? Since this task need to be done in a short period of time, the learning curve using the SDK and software development tool may take too long..
Thanks!
Sun
  • jafoste4
    0 jafoste4 over 8 years ago
    Hello Sun,
    My suggestion to you would be to review the two simple barmetal SPI controllers that control a PMOD application.
    Please refer to Tutorial 06 and Tutorial 07 located here http://picozed.org/support/design/13076/106
    These tutorials demonstrate the use of either a PS or a PL SPI Controller.
    --Josh
  • sunsun1437
    0 sunsun1437 over 8 years ago in reply to jafoste4
    Thank you so much for the reply, i will take a look at the tutorial.
    -Sun
