ZedBoard Hardware Design RJ45 center tap connection?
  • Subscribers 359 subscribers
  • Views 951 views
I am curious why the VCC connection of the RJ45 connector was left floating? Did I misread the schematic (revD.2)? Assumption is that the RJ45 connector uses the VCC connection as a center tap voltage. In the XC7Z02, the RJ45 center tap (VCC) is tied to VCC_MIO (2.5V).
Andreas
  • bhfletcher
    0 bhfletcher over 13 years ago
    This is based on the requirements for the Marvell 88E1518 PHY Check out document MV-S301716-00A. The ZC702 uses a different PHY which does require the center tap to be connected.
    Bryan
    Thanks! Went back and took a look at the difference between the 1318 and 1518 and of course you are right.:-)
    Andreas
