ZedBoard Hardware Design How can I access block ram on both PS and PL when I use ZedBoard?
  • Subscribers 359 subscribers
  • Views 2486 views
Hello everybody~
Now I have a question. I need archive this:
1. send data from PS to bram in PL by AXI.
2. read bram in PL.
For first task, I think I can use axi-bram-controller to transfer data. But for second task, I don't know how to access the bram in PL. Do I need design my own bram controller and use it to access the same bram, or just modify the axi-bram-controller to add my own code?
Thanks~~ :D
  • drozwood90
    0 drozwood90 over 10 years ago
    Hi there,
    I suggest that you use a DUAL PORT BRAM. This way, you can have the PS read from it, while you write to it. I would start with the AXI BRAM Controller. Then you can use one of the BRAM ports to allow the PL to read the memory, while the PS can fill the memory using AXI.
    In this case, you will need to create your own BRAM interface as you would using any other instantiated BRAM.  There are timing diagrams and logic flow diagrams in the datasheet to assist you in this design.
    --Dan
    0 e14 Contributor over 10 years ago in reply to drozwood90
    I think what you said is a great solution~ Even though I still need to learn how to write a bram controller :D
    did you guys solved the problem yet?
    I am implementing this kind of solution but something doesn't work.
    I try to write from an application on my operative system in the bram, then I try to read the data from fpga. The reading process is destructive, I can see the data turned into zero while my code is running.
    How is that possible?
    The opposite procedure: writing with fpga and readig from operative system totally works.
    Please let me know if you have any advice
    Marina
    Marina
    Hello Marina,
    This interface should be pretty straightforward. Just implement an AXI BRAM controller connected to one port of a Dual Port BRAM. Connect your PL (Programmable Logic) design to the other port of the Dual Port BRAM. Reading from the Dual Port BRAM via the AXI BRAM controller should not alter the contents of the BRAM.
    I would suggest looking at the addressing and the data width of your AXI interface to the BRAM. And make sure that your PL design is not causing the issue. Take a second look at your software to make sure you are only performing reads.
    -Gary
    Thank you for the replay. I recently discovered that I had a bad management of the write enable array of the bram. So I am actually able to read what the axi is writing on the bram, using my block of vhdl.
    Unfortunately another problem occurred. Now my axi seems not to be able to read what has been written by the vhdl block, but is totaly capable to read what he wrote before.
    Should I look to my enable signals and stuff in the vhdl or might this be related to memory caching and so on? (somebody pointed that out online but I am pretty confused)
    I am using the mmap function to access the memory space.
    Thanks for your help and any advice anybody would be able to provide
    Marina
