ZedBoard Hardware Design Install OLED module drivers on Linux
  • Subscribers 359 subscribers
  • Views 421 views
Hi everybody.
I am using Zedboard coupled with a FMCOMMS1 board working on the Linaro OS provided by Analog Devices. Unfortunately on this OS image, the OLED isn't implemented.
I checked also with the original test Linux image of Zedboard and the scripts are working perfectly.
Unfortunately, I looked all over the internet and I didn't find an answer to this problem yet.
I'm using the next reference files from Digilent Github :
https://github.com/Digilent/linux-digilent/tree/master/drivers/pmods
But I don't know how to install the drivers and make it work with Linux.
Does someone have an idea ?
Thanks.
  • bhfletcher
    Did you already check the source for the ZedBoard out-of-box image?
    http://www.zedboard.org/node/241
    If that doesn't give you the answers that you need, I suggest you contact Digilent Technical Support at support@digilentinc.com
    Bryan
    0 Former Member over 11 years ago in reply to bhfletcher
    I already used the ZedBoard image. Everything was working ok (the OLED launching at the beginning with Digilent logo) and I tried to understand with no success how the OLED driver is working.
    This is the content of the script load_oled.sh :
    #!/bin/sh
    insmod /lib/modules/`uname -r`/pmodoled-gpio.ko;
    if [ -c /dev/zed_oled ]; then
            cat /root/logo.bin > /dev/zed_oled;
    fi;
    I downloaded the logo.bin from the Zedboard original image, but I don't know what to know with the rest of the code located here : https://github.com/Digilent/linux-digilent/tree/master/drivers/pmods
    I want to continue the research on it before contacting Digilent support.
    I will post if I've any news.
