ZedBoard Hardware Design Turn led ON when fifo is full
  • Subscribers 359 subscribers
  • Views 451 views
Hi, I am writing a stream of data to DDR and then reading that data and writing it to sdcard. But the writing on DDR starts when there is valid from my input and ready from AXI DMA. As now i want to write data of ADC to DDR there will be no "ready" from DMA. I want to use in between fifo. First i want to write data to fifo untill an interrupt came and when there is an interrupt transfer fifo's data to DDR and the cycle continues.
Help needed for:
How can i use fifo to write data to fifo and read data from fifo? And Then turn the led on ZedBoard ON when fifo is full.
Regards;
  • bhfletcher
    0 bhfletcher over 10 years ago
    Have you also asked this same question on the Xilinx forums? I would recommend that since this is a specific question internal to Zynq. It would be helpful to know which FIFO IP that you are using.
    Bryan
    0 Former Member over 10 years ago in reply to bhfletcher
    Hey bryan i am using axi4 stream FIFO IP.
  • bhfletcher
    0 bhfletcher over 10 years ago in reply to Former Member
    Have you looked at the examples in the Xilinx tool installation?
    C:\Xilinx\SDK\2015.2\data\embeddedsw\XilinxProcessorIPLib\drivers\llfifo_v5_0\examples
    Bryan
