ZedBoard Hardware Design NAND on zed board.
  • Subscribers 359 subscribers
  • Views 485 views
NAND on zed board.
Hi All,
May be I am asking a stupid question, but I need some information for the possibility.
Is there any possibility to connect NAND hw part to zed board. please share information.
Jagan.
  • bhfletcher
    0 bhfletcher over 13 years ago
    There are 2 possible ways to connect NAND to Zynq:
    1.   Using the built-in NAND controller in the PS (MIO required)
    2.   Using IP in the PL for the NAND controller to connect to NAND via PL I/Os
    I assume you are referring to the PS-NAND.  Unfortunately, we did not design the ZedBoard to allow NAND connection via the PS.  You could investigate the 2nd option to connect NAND via the PL, but this would not be a bootable memory.
    What would you like to do with the NAND?
    Bryan
    Actually I need a PS-NAND, where I could boot from it.
    If the nand is possible with zedboard, then it is a complete embedded board with sd/nor/nand boot modes are available. This will help many developers/students .. for doing some experiments.
    Any design possibility for PS-NAND?
    Jagan.
  • bhfletcher
    Jagan,
    I am not aware of anyone building an evaluation board with bootable NAND.  I think the biggest issue with NAND as a boot device is the wear leveling.  That boot block of memory will be hit over and over again.
    I suggest you check out this design from Enclustra.  I think they have spent the most time investigating NAND with Zynq, and they have chosen a hybrid model with bootable QSPI then switch-over to NAND.
      http://www.enclustra.com/en/products/system-on-chip-modules/mars-zx3/
    Bryan
