ZedBoard Hardware Design design failed to meet timing constraints
  • Subscribers 361 subscribers
  • Views 598 views
Hello Every one,In my design i am using to clock one is at 100MHz and another one is at 200MHz.After synthesis when i implementing the design i got an error as design failed to meet timing constraints,Hence anyone please help me how to resolve this issue.
  • jafoste4
    0 jafoste4 over 9 years ago
    Hi Babuji,
    I am going to ask that you provide more information as to what your design is doing. It could be any number of reasons based on the information your provided. Did you check the timing report? You are using Zedboard correct?
    --Josh
    0 e14 Contributor over 9 years ago in reply to jafoste4
    Iam using ZC706,in that the design is about modulation and demodulation.I created IPs for both and then interface with the processor
  • jafoste4
    Hi babuji,
    Seeing how you are using a xilinx board I am going to suggest you ask your question over there as they are they are more familiar with your hardware.
    https://forums.xilinx.com/
    However, you should first check your timing report to get an idea what failed.
    --Josh
