ZedBoard Hardware Design New Clock
  • Subscribers 359 subscribers
  • Views 322 views
New Clock
deaxman
deaxman over 12 years ago
I am using Xillinux and editing the file xillydemo.  I have tried to insert a new clock by generating IP by using the clocking wizard in the xilinx core generator.  I generate the core, then I take the UCF file and merge it with the xillinux one and I add the verilog file to my xillinux (xillydemo) project and parameterize it as a module by passing in clk_100 (GCLK under Y9) under CLK_IN1 and taking out CLK_OUT1.  It keeps giving me an error saying that "Port <clk_100> has illegal connections. This port is connected to an input buffer and other components." even if I don't directly patch clk_100 in but instead assign it to another wire and feed that into the module.  I know how to remove this warning under the sythesis properties but that doesn't seem like the right thing to do.  I would rather figure out why it is giving an error and fix it (removing the error forcefully only generates more errors).  Thanks!!
  • deaxman
    0 deaxman over 12 years ago
    source changed to no buffer in first page of the generator prompt
