ZedBoard Hardware Design Adding a 640x480 camera to your Zedboard
  • Replies 23 replies
  • Subscribers 363 subscribers
  • Views 3404 views
Hi all.
I've adapted a low-cost VGA camera module to interface with the Zedboard over PMODA and PMODB. About $15 worth of hardware and no soldering to give your Zedboard eyes!
As the PL has four PMODs you should even be able to give it stereo vision.
It is currently showing a picture on the Zedboards Analogue VGA out, but I want to test and polish it just a little more before I release the code - tweak some of the camera's registers values and so on.
I've added a community project, and will put the code up as soon it is ready. If in the short term you would like the code, just email or message me.
Kind regards
Mike
  • mangibu
    0 mangibu over 13 years ago
    This is a very interesting project. Thanks for sharing.
    Michael
    0 Former Member over 13 years ago
    Are you also developing a module to transfer the image to DDR memory via AXI HP ?
    The project is pretty much complete - I would like to add a way to store the image in the DDR memory, but that is beyond my skills at the moment.
    I've also discovered that the cameras I am using do not have infra-red filters, so the colours are all mixed up.
    Also, although the cameras are 640x480 on a 25MHz clock they are only 30 frames per second, as a pixel requires two clocks to transfer.
    Chris put in the time to work out what was wrong with the colours, and has produced an excellent result (see sample on project page at http://hamsterworks.co.nz/mediawiki/index.php/Zedboard_OV7670).
    I'll updated the project archive as soon as I get a chance, but for now the updated source is available on the page too.
    Mike
  • roman3017
    0 roman3017 over 13 years ago in reply to Former Member
    i have combined these two projects of yours. got it working but quality is rather low. are you planning to display camera over hdmi in the future?
    I've made a little PCB to mate the camera module to the PMODs. The minimum order was 10, so I have a few left over. If you would like the bare PCB send me an email (hamster at snap dot net dot nz).
    If you want I can also send you the design files - it cost me US$15 to get 10 PCBs made.
    0 Former Member over 13 years ago in reply to roman3017
    I would like to, but I don't really have the time/need to build the skills required to store the frame buffer in DDR memory...
    Maybe one day when I have more time on my hands!
    hi
    can you explain how can i attach a usb camera to a pmod.
    or if is possible to use the micro usb to connect the camera directly to zedboard
    0 Former Member over 12 years ago in reply to Former Member
    Hi
    I have used Zedboard Ov7670 project successfully. I want to use the Zedboard Hdmi project along with the Zedboard Ov7670. Can u please help me to merge both. It will be helpful for my Master's project. Any changes required to be done in the vhdl part for the camera interface in zedboard and hdmi display.
    Please guide me. Thanks
    My email id is shrivats001@e.ntu.edu.sg
    have you found any answer to your question coz i am also for somehting similar i.e usb camera interfaced to zedboard.
