ZedBoard Hardware Design JX3 Connector Pins Pulling Away From PCB
  • Subscribers 360 subscribers
  • Views 1002 views
  • zedboard
lewilson_2000
lewilson_2000 over 5 years ago
I have two UltraZed boards where the JX3 connector pins have separated from the pcb board and have pulled up the solder pads.  I would like to do an RMA either to repair or replace the boards.
Larry Wilson
512-567-3758
  • narrucmot
    0 narrucmot over 5 years ago
    Did you receive the SOMs with the JX3 pins separated from the PCB?  The boards are supposed to have been boot tested before shipping, so this is an unusual failure.  Please contact your nearest Avnet office to start the RMA process:
    http://avnet.me/avnet-locations
    --Tom
  • lewilson_2000
    0 lewilson_2000 over 5 years ago in reply to narrucmot
    No, the boards didn't come this way.  This happened after removing the UltraZed from the Zed carrier board.
