Azure Sphere Starter Kit
  • Azure Sphere Starter Kit
Blog Az as simple web server w/ demo of change wifi network via web server
  • Author Author: saicheong
  • Date Created: 20 Oct 2019 6:25 PM Date Created
  • Views 1186 views
saicheong
saicheong
20 Oct 2019
A simple web server for Azure Sphere
w/ demo for change wifi setting via web server
Install
Simple clone it and complie at visual studio.
Running
The programe start at SSID: First and Open network (No password), so the device try to connect to AP as open network with SSID First.
Change of WIFI network is easy, just access ip:8080 on browser, select new network, put psk password and click submit.
To Reset the wifi, click REMOVE.
Web Server
The web server support GET method to receive feedback from client, relative code should wrote inside web_interact function at web_tcp_server.c, two array get_name and get_value for GET parameters with filename and filetype support for custom data, also with a str_replace class for easy modify of html documents, html content <!!!---%s will be replaced by the string specified.
html and relative resources should inserted under visual studio "Resources Files", ensure content select "true", the Properties "Relative Path" also is the path of web server.
The web server support htm/html/txt, and image jpg/gif, as well as compression document such as zip.
Due to restrict of memory, file should smaller that about 35kb, otherwise will easy to SIGKILL (out of memory).
Source code: https://github.com/sicreative/azWebWifiSetting
  • xeonaj
    xeonaj over 6 years ago
    GREAT!
