Azure Sphere Starter Kit
  • Azure Sphere Starter Kit
Forum Avent Azure Sphere stopped working!
  • Subscribers 54 subscribers
  • Views 771 views
  • bricked
dbj1906
dbj1906 over 7 years ago
This morning, I woke up to a bricked device; not sure what happened - everything worked fine as of last night. Is there a process/protocol to get a replacement component?
  • Gough Lui
    Gough Lui over 7 years ago
    How bricked is it? Any LEDs? Serial Ports in Device Manager? IP Address on the Wi-Fi you can ping?
    - Gough
  • clem57
    clem57 over 7 years ago in reply to Gough Lui
    I found unplugging and re-plugging should blink some lights. If not, a short must have occurred.image
  • mvp
    mvp over 7 years ago in reply to clem57
    Had the same problem 3 days ago. It seams to be the fault of the 3.3 V DC/DC onboard regulator. No solution to this problem. Other components could be also damaged, so that regulator replacement is not an option.
  • dbj1906
    dbj1906 over 7 years ago in reply to Gough Lui
    Mine is totally bricked... no leds, to ports, nothing....  it's a glorified coaster at this point. Any chance I can get a new one?
  • clem57
    clem57 over 7 years ago in reply to dbj1906
    dbj1906 try to connect the USB micro cable to a know working power supply to eliminate other issues like a bad USB port. Also try different cable. My cable came really kinked up and may have issues later on (broken wire!image).
    Clem
