Azure Sphere Starter Kit
  • Azure Sphere Starter Kit
Forum URL response Fail!
  • Replies 59 replies
  • Subscribers 70 subscribers
  • Views 5726 views
  • azure sphere kit
URL response Fail!
stevesmythe
stevesmythe over 7 years ago
I can't connect to the server this morning. It fails with code "error" : "0". It has worked every other day I have tried (53 so far!).
  • peterfenn
    peterfenn over 7 years ago +6
    Note ! The Azure Sphere contest registration issue encountered by many of you this past weekend has been resolved A DNS resolution issue occurred following a server migration, which has since been corrected…
  • Gough Lui
    Gough Lui over 7 years ago in reply to Gough Lui +5
    The problem in my tracing seems to be an NXDOMAIN returned for avnetagent.iotconnect.io It seems that some servers can still resolve it, whereas others cannot. Result is: 13.77.82.141 173.201.188.161 Perhaps…
  • stevesmythe
    stevesmythe over 7 years ago in reply to Gough Lui +5
    Gough Lui wrote: The fact it is down is a big let-down for the current "raffle" competition. Or indeed for anybody who is still looking for their 15/30 consecutive day syncs (I know this will be taken…
  • cline
    cline over 7 years ago
    Hi, see if this thread helps contest registration app problem
    I have the same problem, I haven't solved it yet.
  • Gough Lui
    It's not only you ... I'm having trouble too. I suspect they probably have an issue with their server, routing or DNS.
    - Gough
  • Gough Lui
    Result is:
    13.77.82.141
    173.201.188.161
    Perhaps shoving it into your HOSTS file could temporarily overcome the issue.
    EDIT: Confirmed, adding the binding of 13.77.82.141 avnetagent.iotconnect.io into my HOSTS file, flushing DNS resolver cache (ipconfig /flushdns) and restarting the app allowed it to submit correctly.
    - Gough
    • Vote Up +5 Vote Down
  • cline
    cline over 7 years ago in reply to cline
    following the thread's advice making this change has worked, getting the email confirmation now.
    13.77.82.141avnetagent.iotconnect.io to  c:\Windows\System32\drivers\etc\hosts
  • Gough Lui
    danzima - any chance you guys can look into why your DNS servers aren't reliably propagating?
    - Gough
  • stevesmythe
    I added 13.77.82.141 avnetagent.iotconnect.io into hosts, flushed the DNS resolver cache and restarted the app. The url is resolving correctly but can't be reached. I also tried 173.201.188.161. It seems I have a different problem.
  • Gough Lui
    Gough Lui over 7 years ago in reply to stevesmythe
    I don't believe that you can ping the address - the server at 13.77.82.141 there doesn't seem to respond to pings, but the one at 173.201.188.161 does.
    I suspect perhaps a firewall or un-cooperative ISP/router? Perhaps worth trying a tracert to each server and seeing where the trail ends. For me, it seems that my traffic (from AU) arrives at LAX then gets sent through SN, AT, BN (all MSN) before being "lost" in a sea of non-responding routers for 13.77.82.141. For the other, my traffic arrives at LAX, then goes through ASH, EQIX (GoDaddy) before ending up at one of their shared hosting/VPSes.
    Have you also tried restarting your router? Else if you have a VPN, you could try going through that.
    - Gough
  • cline
    cline over 7 years ago in reply to stevesmythe
    It was working when I just changed the host file.
    But after running ipconfig /flush dns . it has stopped working, the url response fail is back.
  • Gough Lui
    Gough Lui over 7 years ago in reply to cline
    Flushing DNS Cache is necessary in case there is a NXDOMAIN response cached, which will result in it failing (quickly) for a while until the entry expires. HOSTS entry should override the need to actually resolve it. Try clicking the 'Send to Server' button more than once. I suspect there may be another name which it tries to resolve that is not the one we have singled out which might explain the failure ...
    - Gough
  • Gough Lui
    I just tried again and for me, it seems to hang for a while and then fail. It might be a problem with Microsoft's servers as well. Oh well ...
    Doing more digging - it looks like avnetagent.iotconnect.io is actually corresponding to a CNAME record pointing to:
    • poc-iotconnect-app-agent-eu.azurewebsites.net.iotconnect.io (with a TTL of 4 hours, which comes up NX)
    Most nameservers queried at dnslookup.online show that it's NX.
    There is one with a record still existent is OpenDNS at 2620:0:ccd::2 which states that it is a rather long CNAME chain:
    avnetagent.iotconnect.io -> poc-iotconnect-app-agent-eu.azurewebsites.net -> waws-prod-bn1-045.sip.azurewebsites.windows.net -> waws-prod-bn1-045.cloudapp.net -> 13.77.82.141
    There is another which is okay which is Comodo Secure DNS at 8.26.56.26/8.20.247.20 which goes:
    avnetagent.iotconnect.io -> poc-iotconnect-app-agent-eu.azurewebsites.net.iotconnect.io -> iotconnect.io -> 173.201.188.161
    - Gough
