Azure Sphere Starter Kit
  • Azure Sphere Starter Kit
Forum Have done IoT Hub configuration
  • Subscribers 51 subscribers
  • Views 549 views
pkumar1883
pkumar1883 over 7 years ago
Hi All,
I have created Azure IoT Hub successfully.
Now I am trying to run Azure IoT code example. I have made following updated following field in my app_manifest.json--
1. DeviceAuthentication
2. CmdArgs
3.  AllowedConnections
Program build is successful.
But when I am debugging my program. I am getting following error-
IoTHubDeviceClient_LL_CreateWithAzureSphereDeviceAuthProvisioning returned 'AZURE_SPHERE_PROV_RESULT_PROV_DEVICE_ERROR'.
ERROR: failure to create IoTHub Handle - will retry in 60 seconds.
Please anyone can help.
  • bwilless
    bwilless over 7 years ago +1
    Hi Pushpendra, It looks like maybe your DPS may not be correctly configured. Please review the steps you went through; the first thing I would check is to make sure you created the "Enrollment Group" in…
  • pkumar1883
    pkumar1883 over 7 years ago in reply to bwilless +1
    Hello Everyone Good news problem solved. Actually in app_manifest.json I have deleated default value from AllowedConnection. So added "global.azure-devices-provisioning.net" to AllowedConnection fiweld…
  • danzima
    danzima over 7 years ago
    peterfenn
    bwilless
    Hi folks, do you have any insights on the above question?
  • bwilless
    Hi  Pushpendra,
    It looks like maybe your DPS may not be correctly configured.  Please review the steps you went through; the first thing I would check is to make sure you created the "Enrollment Group" in your DPS instance and that it's using the certificate that you used when proving to DPS that you own your tenant.
    Let me know what you find,
    Brian
  • pkumar1883
    Hello Everyone
    So added  "global.azure-devices-provisioning.net" to AllowedConnection fiweld and now it is working.
    I am getting below messages--
    [Monitor D2C Message] [17-09-2019 17:41:47] Message received on partition 0:{ "Temperature": "29.75" }
