Azure Sphere Starter Kit
  • Azure Sphere Starter Kit
Forum AES-MS-MT3620 module pinouts
  • Replies 11 replies
  • Subscribers 51 subscribers
  • Views 1707 views
wizio
wizio over 7 years ago
ONLY module pinouts?
  • peterfenn
    peterfenn over 7 years ago in reply to wizio +1
    Georgi Good job - you are a rock star with the extent of your Azure Sphere deep-dives! I am very interested to find-out more detail on this topic. Will you be sharing on your github site? -Peter
  • wizio
    wizio over 7 years ago in reply to peterfenn +1
    this is "research" folder... https://github.com/Wiz-IO/LIB/tree/master/TAP_TUN_SLIP at the end must be azsphere for all platforms Win, Lin, Mac... at least so I think there is still much to do Today the…
  • wizio
    wizio over 7 years ago +1
    TADA !!!
  • peterfenn
    The module pinouts are detailed in Appendix-A of the Starter Kit Hardware User Guide document
    Hardware User Guide - Azure Sphere MT3620 Starter Kit
    (Located under the Technical Documents tab, of the  Azure Sphere Starter Kit product page)
  • wizio
    Thanks Peter !
    The board pins is the Module pins?
  • peterfenn
    peterfenn over 7 years ago in reply to peterfenn
    The module pinouts are also detailed on page 14 and 15 of the module Datasheet and User Manual
    Datasheet and User Manual - AES-MS-MT3620-M-G Module v1_3
    (Located under the Technical Documents tab, of the Azure Sphere Module product page)
    The module pads and the corresponding MT3620 device pins are tabled in both documents
  • wizio
    Thanks Peter !
    I found what I was looking for...
  • wizio
    It`s work !!!
    azsphere on python image
  • peterfenn
    Georgi
    -Peter
  • wizio
    at the end must be azsphere for all platforms Win, Lin, Mac... at least so I think image there is still much to do
    Today the module answer of HTTPS request over USB/upload port ( screenshot, marked lines )
    https://github.com/Wiz-IO/platform-azure/wiki/AZSPHERE-protocol
  • wizio
    image image image ... for Unix-Like need only application packer
  • wizio
    with azure packer meta data will be hard ...
    the image is "ready" have only 4 ??????
    https://github.com/Wiz-IO/LIB/blob/master/TAP_TUN_SLIP/az_packer.py
  • wizio
    I move project to new git location - if someone want to help....
    https://github.com/Wiz-IO/azure-sphere-reverse-engineering
