Azure Sphere Starter Kit
  • Azure Sphere Starter Kit
Forum Driving Piezo speaker (Buzzer)
  • Subscribers 52 subscribers
  • Views 1063 views
  • piezo-electric
  • buzzer
  • avnet azure sphere
sagacr2018
sagacr2018 over 6 years ago
Can I drive a Piezo Speaker using Avnet Sphere Kit ? I tried to connect to PWM_0 of Kit and tried to convert Arduino Code to Avnet but failed. Arduino use internal timer to send Analog Signals but I am not able to figure out how to use Timer on Avnet Kit.
Have anyone done it ?
  • bwilless
    bwilless over 6 years ago +1
    Hi Rohit, There is an example here: https://github.com/Azure/azure-sphere-samples/tree/master/Samples/PWM/PWM_HighLevelApp that shows hw to drive a PWM signal. It looks like the example varies the intensity…
  • Sean_Miller
    Sean_Miller over 6 years ago +1
    The PWM example Brian mentioned should get you going. Before the hardware had PWM going a few months ago, I did a software based PWM for my piezo leveraging some Arduino code. With the piezo buzzer I was…
  • danzima
    danzima over 6 years ago
    peterfenn
    bwilless
    Any insights about the above?
  • bwilless
    Hi Rohit,
    There is an example here: https://github.com/Azure/azure-sphere-samples/tree/master/Samples/PWM/PWM_HighLevelApp  that shows hw to drive a PWM signal.  It looks like the example varies the intensity of an LED.  This example should have all the details you need to get your piezo speaker working.
    Brian
  • Sean_Miller
    Before the hardware had PWM going a few months ago, I did a software based PWM for my piezo leveraging some Arduino code.  With the piezo buzzer I was using, I found that setting the period and duty parameters took trial and error to first get a tone and then to get what I considered a good tone.
    So, if it doesn't give you want you want, you may want to do a For...Loop that increments through the period values and outputs a number to the console.  Then listen for what you like.
    For example, for my piezo, to get a chirp , I had 400000 (period), 40000 (active).
    See ya',
    Sean
  • sagacr2018
    sagacr2018 over 6 years ago in reply to bwilless
    Thanks Brian. It'll help.
  • sagacr2018
    sagacr2018 over 6 years ago in reply to Sean_Miller
    Hey Sean,
    I got your point. I'll run a for loop for different combinations to see outcome. It'll need earbuds though image
