Azure Sphere Starter Kit
  • Azure Sphere Starter Kit
Forum Anyone else find the lack of a MT3620 datasheet odd?
  • Replies 16 replies
  • Answers 6 answers
  • Subscribers 55 subscribers
  • Views 4486 views
  • azure sphere
  • azure sphere mt3620 starter kit
  • mt3620
Fred27
Fred27 over 7 years ago
Considering the effort and expense that is being put into promoting the Avnet Azure Sphere MT3620 starter kit, does anyone else find it odd that the MT3620 datasheet is not publicly available? Sure we have example code and you can infer a lot from that, but as far as I can tell any proper information on the MT3620 is available only under NDA. (The M4F core datasheet is at least.)
I can understand that maybe not everything is appropriate to be public. It must also be tricky when there are multilple companies involved - the board manufacturers (Avnet et al.), the silicon manufacturer (MediaTek) and the ecosystem provider (Microsoft). However, if you're trying to encourage people to use a device then the more clear information and documentation you can provide the better the uptake is likely to be.
  • bwilless
    bwilless over 7 years ago +4 suggested
    MediaTek just released a non-NDA version of the MT3620 datasheet. It can be found here: http://avnet.me/mt3620-datasheet
    michaelkellett over 7 years ago in reply to segnini75 +3
    One again, not a data sheet for the chip - no details on theis document, just tells you how the chip is connected inside a module. What we need is a proper user manual/data sheet for the chip whcih ngives…
    michaelkellett over 7 years ago +2
    It's amazingly weird. I though only Broadcom were that odd. Have you managed to get the data sheet or are they sniffy about who they sign up as well ? I've looked at the Microsoft Support Status document…
    0 michaelkellett over 7 years ago
    I've looked at the Microsoft Support Status document and emailed Avnet for more info - I'll keep you posted.
  • danzima
    0 danzima over 7 years ago
    Hi folks, I've reached out to a few Avnet folks about this, I will send you any updates as I get them!
    0 michaelkellett over 7 years ago in reply to danzima
    Thanks !
  • Fred27
    0 Fred27 over 7 years ago in reply to michaelkellett
    They were ok about it - just said it would be under NDA. As my primary reason was to learn about it and probably write things up here, it didn't seem appropriate and I didn't take it any further. What would I write? "I know loads of cool stuff but i can't tell you about it."
  • mkv2
    0 mkv2 over 7 years ago
    Don't know if this is a result of one of you - but I think it's listed on Farnell's product page now:
    https://uk.farnell.com/avnet/aes-ms-mt3620-sk-g/starter-kit-arm-cortex-a7-cortex/dp/3106884
    Or directly here: http://www.farnell.com/datasheets/2819361.pdf
  • Fred27
    0 Fred27 over 7 years ago in reply to mkv2
    That's not what I mean. I'm talking about a datasheet for the MT3620 chip. (There is a product brief available, but that's not really detailed enough.)
  • segnini75
    0 segnini75 over 7 years ago
    http://cloudconnectkits.org/sites/default/files/Datasheet%20and%20User%20Manual%20-%20AES-MS-MT3620-M-G%20Module%20%28v1…
    0 michaelkellett over 7 years ago in reply to segnini75
    What we need is a proper user manual/data sheet for the chip whcih ngives FULL details of how the peripherals work and are accessed and controlled.
    (For reference check out the referance manuals and data sheets ST provide for their STM32xxxxx range of ARM based micros.
  • cstanton
    0 cstanton over 7 years ago
    As discussed here: Re: Where do I find details on using the M4F cores on the Azure Sphere?
    The way to find out the information you're after is to sign the Non Disclosure Agreement for the hardware by counter-signing an NDA which is requested via Azure.Sphere@avnet.com
    The thing to remember is that the chip on the board is designed specifically for Microsoft, and any functionality/features are controlled/made available to the user as Microsoft want it to be, this is by design and to maintain security of what's accessible. To change this functionality would require an operating system rewrite on the chip, and I doubt (but don't hold me to it) this is possible on the received AzureSphere kits (and I am not convinced it's worthwhile).
    However, that being said, by all means get in touch with them, sign the NDA and it's pretty harmless finding out for personal or company use.
  • Fred27
    0 Fred27 over 7 years ago in reply to cstanton
    It didn't sound too onerous to sign the NDA. However, the main reason I want to look at it is to understand the device and potentially blog about it here, so it might be a bit counterproductive.
