Azure Sphere Starter Kit
  • Azure Sphere Starter Kit
Forum No Azure server connection but WiFi connected
  • Replies 7 replies
  • Subscribers 52 subscribers
  • Views 1181 views
psn1
psn1 over 7 years ago
I have tried to run my new mobo
Followed this  Cabe Atwell's Getting Started Guide
https://hackster.us7.list-manage.com/track/click?u=3fd72855783c7f1a97812d84e&id=4ff0833875&e=537bbb3615
Updated OS (by azsphere device recover)  to 19.09
Successfully connected to wifi:
SSID                : *
Configuration state : enabled
Connection state    : connected
Security state      : psk
Frequency           : 2452
Mode                : station
Key management      : WPA2-PSK
WPA State           : COMPLETED
IP Address          : 192.168.2.133
MAC Address         : *
I have complete Getting Started Guide but data from my device are not sent to server.
My investigation:
I have added to the ShockDetect project
bool isNetworkingReady = false;
if ((Networking_IsNetworkingReady(&isNetworkingReady) < 0) || !isNetworkingReady) {
Log_Debug("\nNetwork is not up.\n");
Log_Debug("%s (%d).\n", strerror(errno), errno);
and receive error
Network is not up.
No error information (0).
I have tested also from azure-sphere-samples
1. PrivateNetworkServices project with interface changed to wifi
output
INFO: Networking_GetInterfaceCount: count=1
INFO: Networking_GetInterfaces: actualCount=1
INFO: interface #0
INFO:   interfaceName="wlan0"
INFO:   isEnabled="1"
INFO:   ipConfigurationType=1 (DhcpClient)
INFO:   interfaceMediumType=1 (Wi-Fi)
INFO:   interfaceStatus=0x0f
2. CurlEasyHttps project
OutPut
Not doing download because network is not up.
So I have
Networking_IsNetworkingReady - false
but
Networking_GetInterfaceConnectionStatus - 0 (So OK)
I have found this issue about similiar problem
https://github.com/Azure/azure-sphere-samples/issues/84
The reason was device have not sync time server.
I have tried to use Retail Evaluation Azure Sphere OS feed and try OS 19.10
azsphere device link-feed --feedid 82bacf85-990d-4023-91c5-c6694a9fa5b4
but after
azsphere device image list-targeted
I received
Received HTTP response: 404 (Not Found)
I have checked two access points with and without PSK key.
Contest App shows green that I am connected
  • psn1
    psn1 over 7 years ago +1
    I have tried with third wifi access point - Android Phone - and it started working! I will try find out what was the problem. Maybe I should try check some Internet gate and DNS setup on dev kit
  • wizio
    0 wizio over 7 years ago
    Log_Debug( Networking_IsNetworkingReady(&isNetworkReady) ); ... is "bad"
    Log_Debug is equivalent of printf, the first parameter must be format string...
    int Log_Debug(const char *fmt, ...);
    some like that
    https://github.com/Wiz-IO/framework-azure/blob/master/arduino/core/common.cpp#L7
  • psn1
    0 psn1 over 7 years ago in reply to wizio
    I have corrected this:
    Log_Debug("\nNot doing download because network is not up.\n");
    Output:
  • wizio
    0 wizio over 7 years ago in reply to psn1
    are you config wifi?
    azsphere dev wifi
  • psn1
    Yes
    SSID                : *
    Frequency           : 2452
    Mode                : station
    MAC Address         : *
    After I commented out part of HTTPS_Curl_Easy responsible for Networking_IsNetworkingReady checking, application correctly connected to external server and downloaded webpage content.
    But after I omitted Networking_IsNetworkingReady part from  ShockDetect project I received
    IoTHubDeviceClient_LL_CreateWithAzureSphereDeviceAuthProvisioning returned 'AZURE_SPHERE_PROV_RESULT_NETWORK_NOT_READY'.
  • wizio
    try as this
    https://github.com/Wiz-IO/framework-azure/blob/master/arduino/core/common.cpp#L4
    while and delay
    there is "hidden" process on module reset  for DNS and SNTP
  • psn1
    Waiting does not help. Stucked on waitWifi()
  • psn1
