Azure Sphere Starter Kit
  • Azure Sphere Starter Kit
Forum OLED connectors to the kit?
  • Answers 3 answers
  • Subscribers 52 subscribers
  • Views 1352 views
  • azure sphere kit
skruglewicz
skruglewicz over 6 years ago
Hi
I have ordered the OLED display recommended in the blog post
Avnet Azure Sphere Starter-Kit: Advanced Tutorial
by peterfenn
128x64 Yellow Blue SSD1306 I2C OLED Display [optional]
eg. this one for $6.99 from Amazon...
https://www.amazon.com/gp/product/B072Q2X2LL/
My questions are,
Has anyone used headers and jumper wires to connect this display?
And if so is this the preferred way to  connect the Display to the Kit?
And what parts did you use.?
Would A solder less header be possible for the solution? (my soldering dexterity is limited)
Thanks in advance
Steve K
  • clem57
    clem57 over 6 years ago +2 suggested
    I think you may get away without soldiering. Take a look at this https://www.instructables.com/id/4-Ways-to-Connect-a-Wire-Without-Soldering/ . But I want to stress that soldiering is the best electrical…
  • jgroman
    jgroman over 6 years ago +2 verified
    Hi Stephen, it is not mandatory to solder dedicated OLED connector. You can just use 4 DuPont male/female wires and connect the display to I2C pins on either MikroBus socket. Alternatively you could use…
  • skruglewicz
    skruglewicz over 6 years ago in reply to jgroman +1 suggested
    thanks so much for the advice Jaroslav.. my order from Amazon is on it's way. I orderd the following items Glarks 40Pcs 8 Kinds of 2.54mm Breakaway PCB Board 40 Pin Male and Female Pin Header Connectors…
  • clem57
    0 clem57 over 6 years ago
    I think you may get away without soldiering. Take a look at this https://www.instructables.com/id/4-Ways-to-Connect-a-Wire-Without-Soldering/ . But I want to stress that soldiering is the best electrical connection.
  • skruglewicz
    0 skruglewicz over 6 years ago in reply to clem57
    Thank you for responding. I'll take into consideration
  • jgroman
    0 jgroman over 6 years ago
    Hi Stephen,
    Alternatively you could use cables with hook clips (for example like this: https://www.aliexpress.com/item/32798553256.html  ) and hook them to unpopulated OLED display pins on kit - but it is generally unsafe solution.
    In my case I soldered 4-pin female header (like this: https://www.aliexpress.com/i/32858478594.html  ) to the kit and I plug the display right into it without any jumper wires.
  • skruglewicz
    0 skruglewicz over 6 years ago in reply to jgroman
    Glarks 40Pcs 8 Kinds of 2.54mm Breakaway PCB Board 40 Pin Male and Female Pin Header Connectors Kit for Arduino Prototype Shield
    Sold by: Connectors & Wire & Tools
    $9.99
    Elegoo EL-CP-004 120pcs Multicolored Dupont Wire 40pin Male to Female, 40pin Male to Male, 40pin Female to Female Breadboard Jumper Wires Ribbon Cables Kit for arduino
    Sold by: ELEGOO
    $6.98
    UCTRONICS 0.96 Inch OLED Module 12864 128x64 Yellow Blue SSD1306 Driver I2C Serial Self-Luminous Display Board for Arduino Raspberry PI
    Sold by: Arducam
    $6.99
    I'll have a friend solder the header to the board.
    Thanks again
    Steve
  • jgroman
    0 jgroman over 6 years ago in reply to skruglewicz
    You are welcome! image
    Just thought about one more option: Grove to female 4-pin cable like this: Grove System - Seeed Wiki  If you combine it with Grove Expansion board you will never run out of free I2C sockets. Just make sure the pinout is correct when connecting the OLED display.
  • skruglewicz
    Also a great idea thank you
