Azure Sphere Starter Kit
  • Azure Sphere Starter Kit
Forum I2C Resource busy error (errno 16) on OS 19.11
  • Subscribers 52 subscribers
  • Views 986 views
  • i2c
  • azure sphere
jgroman
jgroman over 6 years ago
Since OS 19.11 I am having some trouble with I2CMaster_Write function which fails with with "Resource busy" error a lot when trying to do multiple writes in a row.
For now I managed to create a workaround by using tiny delays before writes:
struct timespec sleepTime;
sleepTime.tv_sec = 0;
sleepTime.tv_nsec = 800000;
nanosleep(&sleepTime, NULL);
result = I2CMaster_Write(i2c_fd, p_ccs->i2c_addr, p_arg_data, arg_int);
Are there any better solutions to this problem?
I cannot send all data in one write transaction as there is limited buffer size in target device.
I have the same problem with multiple different I2C targets.
  • Fred27
    Fred27 over 6 years ago in reply to jgroman +1
    Ah - 19.11 must have just hit the standard channel. I'll update my device and see if it changes anything.
  • jgroman
    jgroman over 6 years ago in reply to Fred27 +1
    Oh, I did the migration thing after update to 19.10, it was confusing for a bit. I noticed this upgrade to 19.11 only after Visual Studio offered Azure Sphere SDK upgrade, too. What I2C bus speed do you…
  • Fred27
    0 Fred27 over 6 years ago
    Are you sure you mean 19.11? That's still in preview so you have to jump through a few hoops to get that on your device.
    I sometimes get that error but had already set up retries due to the repeated start byte problem. A retry seems to cover my use case so I just left it with that.
  • jgroman
    0 jgroman over 6 years ago in reply to Fred27
    Yep, pretty sure:
    >azsphere device show-deployment-status
    Your device is running Azure Sphere OS version 19.11.
    The Azure Sphere Security Service is targeting this device with Azure Sphere OS version 19.11.
    Your device has the expected version of the Azure Sphere OS: 19.11.
    Same code was working fine on previous releases, just after upgrade it started failing.
  • Fred27
    0 Fred27 over 6 years ago in reply to jgroman
  • Fred27
    You're right - 19.11 has landed. I had to jump through quite a few hoops to migrate accounts over before I could "azsphere device show" in order to check.
    I'm definitely getting the occasional error but I don't think they're any more frequent than before. However, mine are "ERROR: I2CMaster_Write: errno=6 (No such device or address)".
    Apparently 19.11 should have fixed the repeated start byte error, so I'll remove my corrective code and see if that's the case...
  • jgroman
    What I2C bus speed do you use in your project?
