Azure Sphere Starter Kit
  • Azure Sphere Starter Kit
Forum Azure Sphere STL library using <vector>
  • Subscribers 50 subscribers
  • Views 2252 views
ehubels
ehubels over 4 years ago
Need to use <vector> in Azure Sphere high-level app. Can't add with #include <vector>, which is a bit of a surprise, I now think that this is related to managed versus unmanaged in VS. Anyone a suggestion how to use configure VS correctly or how I can use <vector> in high-level app.
Erik
  • bwilless
    bwilless over 4 years ago
    Hi Erik,
    I have not done this in any of my projects, but I did a bit of looking around to see if anyone has.  I did not find a quick and easy way for you to use c++ vectors, but may have found a path to get you there.  I found a couple of examples of using c++ in Azure Sphere High Level applications.
    • This example uses CMake and creates a c++ application
      • Use this example to see how the CMakeLists.txt file defined that it was a c++ application
    • This example (pre-CMake) has a custom library that includes a vector.* implementation
    Brian
