Azure Sphere Starter Kit
  • Azure Sphere Starter Kit
Forum Azure Sphere Board interrupt
  • Subscribers 50 subscribers
  • Views 1634 views
  • azure sphere
FrankSteven8877
FrankSteven8877 over 3 years ago
Hi.
I am trying to create a program for GPIO interrupt. Seems the High-level application code will not support IRQ. So I created a Real-time applicable application. When I try to run the HelloWorld example code(https://github.com/Azure/azure-sphere-samples/tree/main/Samples/HelloWorld/HelloWorld_RTApp_MT3620_BareMetal), I got an error saying "libusb_open() failed with LIBUSB_ERROR_NOT_FOUND". Is this error because I didn't connect an usb-to-serial adaptor or I don't install the software LIBUSB? Is it possible debug the real-time applicable application code without the usb-to-serial adaptor? Thanks.
  • bwilless
    bwilless over 3 years ago +1
    Did you run the enable development command with the enable rt debugging option, as admin? > azsphere device enable-development --enable-rt-core-debugging
  • bwilless
  • bwilless
    There are a few items that may slow you down when developing/debugging real time applications on the MT3620.  The recorded webinar at this link element14 Community, can help you understand the nuances of real time development.
