EXPLORE-NFC
  • EXPLORE-NFC
EXPLORE-NFC
Forum Info on emulation
Join EXPLORE-NFC to participate - click to join for free!
  • Subscribers 8 subscribers
  • Views 611 views
Info on emulation
Hi there,
Where can i find more examples, or documentation of how full card emulation is done. We only get a example who emulates a type 2 tag but nxp claims that we can emulate Mifare Classic and Ultralight. I have been digging in the library code, but i really need some documentation on how we could emulate these protocols with the pn512 chip.
Thanks!
  • michaelneurohr
    michaelneurohr over 11 years ago
    Dear Merijn Testroote,
    it is not possible to emulate Mifare Classic card with the PN512. It would require a Mifare Crypto implementation in software which is not available.
    If you need to emulate Mifare Ultralight, then you are almost done. Mifare Ultralight is a Type 2 Tag, hence the provided example shows you how this can be done. Basically if you want to emulate a certain tag / NFC card, you'll have to implement it's command set and memory organization by software.
    All relevant commands for emulating cards can be found in the PN512 data sheet [1]. Most interesting might be page 48.
    Michael
    [1] http://www.nxp.com/documents/data_sheet/PN512.pdf
