Dev Tools
Dev Tools
Forum PCB Thermal Calculator is designed to estimate...
  • Subscribers 79 subscribers
  • Views 855 views
  • calculator
  • pcb
  • design_tool
  • thermal
  • texas_instruments
  • ti
ssilberhorn
ssilberhorn over 15 years ago
TI Analog eLAB PCB Thermal Calculator
The PCB Thermal Calculator is designed to estimate the junction temperatures of components which use exposed-pad packages.
  • The data used in the PCB Thermal Calculator is generated  from measured laboratory data combined with thermal-modeling analysis that uses  a series of thousands of data points.
  • The result of the correlation is used to create the curves and the  data points that appear in the PCB Thermal Calculator.
  • The PCB Thermal Calculator also supports the input of the board  temperature as a reference point. In this case, the junction temperature results  are estimated independently of the PCB layout.
  • Visit the Home Page
  • Download  the PCB Thermal Calculator Widget
  • Download the PCB  Thermal Calculator Application Note
  • If you have a question or  comment visit our support forum
Guides
  • image PowerPadTm Thermally Enhanced  Package (slma002.pdf) Download
  • IC Package Thermal Metrics IC Package Thermal Metrics (spra953.pdf) Download
Related Articles
  • Thermal  Modeling Takes The Heat Off Of Automotive Silicon Design
  • What  is Ambient Temperature, Anyway, and Why Does it Matter?
  • Printed  Circuit Board Cooling Techniques and Strategies for IC Packages
  • A  Quick PCB Thermal Calculator to Aid System Design of Exposed Pad  Packages  Note: IEEExploreCopyright access is required to access the paper.
